Home > In Car Electronics > Reverse Cam Cable Routing
Hello folks,
I'm planning to install a new head unit that incorporates a screen that can take a feed from a reversing camera. The cable from the camera can be easily routed around the inside of the roof and down one of the A pillars but I'm not sure where to go from there. I haven't had the need to dismantle a Puma dashboard yet so I wonder if anybody has any ideas on how to get from an A pillar to the head unit? How much do I need to dismantle to find a route through?
Any pointers (or pictures!) would be much appreciated. Darren
Post #808500 2nd Jan 2020 7:20pm
You’ll find the passenger side easier, if possible but the drivers side can be done.
Remove speaker and open access flap below dash. Ideally centre dash removed too IF needed. No more dash removal needed.
If you don’t have them already, IF you have a need for extra A Pillar room.
Take a look at the ones Mud UK make which are deeper for more room.
You might be able to get away with leaving centre dash / HU cage in place depending on how much stuff you have behind there.
Passenger side has more room, and more convenient to access. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808506 2nd Jan 2020 7:47pm
Ah ok, thanks. That all sounds more straightforward than I thought it might be.
I had a pair of those MUD A pillar trims in my hand at the Peterborough show but decided against them. Obviously wish I hadn't now Rolling Eyes Darren
Post #808536 2nd Jan 2020 9:26pm
They are good, but depends if you need them or not.
What sort of dia cables are you thinking of fitting?
You can probably get away with one or two 4mm max, but beyond that then the Mud trims come into their own.
IIRC, they give you around 10mm extra more than enough.
In my case I had plenty of wiring behind there already at max capacity on standard trims.
I had a 6mm RCA and other wires to fit as well and the Mud trims accepted that with ease.
If you'd like any fitted pics, if you can't find any already on here give me a shout as I could easily snap a couple of pics tomorrow anyway as I'll be working on my 90 tomorrow.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808538 2nd Jan 2020 9:31pm
I'm not sure, off hand. It'll be a standard video cable, the sort with a yellow RCA plug on. It'll probably fit, to be honest. I just need to make sure it doesn't clash with the rear washer pipe. Darren
Post #808541 2nd Jan 2020 9:40pm
You might find the other side from the washer fluid pipe there may just be room.
The tricky parts is avoiding crushing anything.
Good luck. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #808543 2nd Jan 2020 9:54pm
seriesonenut
Hi
I managed to get two cables down that route, a bit tight but they fitted. Not clear shots but you get the idea
monitor by Richard Holmes, on Flickr
20170903_120156 by Richard Holmes, on Flickr
20170903_122501 by Richard Holmes, on Flickr 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
1990 Defender 200tdi CSW (sold)
1989 Land Rover Ninety (sold)
1998 Discovery 2 (sold)
1995 Discovery 1 (auto) (sold)
1990 Discovery 200tdi (sold)
1987 One Ten CSW turbo diesel (sold)
Post #808545 2nd Jan 2020 9:57pm
Ah, excellent, thank you. I also plan to install a very similar camera in that position, too. Darren
Post #808564 3rd Jan 2020 9:03am
