Home > Off Topic > Alternator wiring Cobra replica
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I’m putting a new loom in my cobra replica. Am I correct that the two terminals at the top isolated with black plastic are live with the larger one going back to the starter motor and the smaller live to the loom? The wire back to the starter motor connects to the terminal that has the main battery feed (heavy duty cable) to charge the battery. Then the lower terminal on the alternator is earthed? The alternator came with the car so no instructions. My electrical knowledge is very limited. [/u]
Post #807974 29th Dec 2019 6:32pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Wow, this takes me back around 25 years to when I was in a similar situation building a GD427.
I think you are right - there will also be a small terminal for the charge warning light (brown & yellow wire usually IIRC) Richard
Defender 90 SVX
Post #807982 29th Dec 2019 7:01pm
Martin
Site Admin
There are markings on the body - the one at the bottom is marked W which is the tacho output.
The larger diameter stud will be the main connection to the battery (typically done as a cable to the starter) - it should have B+ near it.
The smaller diameter stud is probably for the dash warning light, it should have D+ near it.
There is also a male spade on the left of the photo but I can’t make out the marking.
Is there a model number on the alternator anywhere?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #808020 29th Dec 2019 10:29pm
Martin
Site Admin
The alternator’s ground reference is to the engine block via its fixings, not normally a separate cable.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #808021 29th Dec 2019 10:30pm
boxoftricks
Thanks Martin. No mode number on it, the stickers have worn blank. Really appreciate your advice Thumbs Up
Post #808027 29th Dec 2019 10:45pm
