![]() | Home > Td5 > Nanocom showing different speed to speedo |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4331 ![]() ![]() ![]() |
Something seems a bit off, all things being equal the Speedo would always read higher than the satnav. 2007 110 TDCi Station Wagon XS
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2228 ![]() ![]() ![]() |
Sure its in mph not kph
techy1664 Member Since: 21 Sep 2019 Location: Cornwall Posts: 12 ![]() ![]() |
AHH, good point. Didn't even think about that. May help if I checked the basics first.
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Even if in kph it is still out. 50kph is 31mph so something is not quite right. Hold my beer and watch this!
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
No there isn't cruise fitted.
I'm new to the nanocom so I will have a look through the settings when I get chance in case Ive missed anything. I'm going to look at the wiring diagrams shortly but thought I'd ask on the forum first. |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 171 ![]() ![]() ![]() |
Nanocom needs to have a correction factor put in to get to mph.
Not sure which menu, but it will be in settings somewhere. Can’t remember if it’s 0.62 to get from kph to mph. |
Right o. Will have a look through the settings tomorrow and give an update. Thanks for the help.
dkmlondon Member Since: 15 Jun 2018 Location: London and Somerset Posts: 14 ![]() ![]() ![]() |
You need to change the speed correction factor on the Nanocom. It’s a bit of trial and error, as my speedo reads fast anyway due to gearing and tyre size. I ended up calibrating Nanocom to mph satnav speed - seemed to make sense! (110 TD5 2006) ********
Best Duncan 2006 110 Td5 CSW / 2001 90 Td5 ragtop lhd / 2017 Disco sport / XK120 |
Managed to sort it out. Started at 0.62 as was suggested and ended up at 0.68, seems to match the speedo.
Thanks for the help |
