Home > Technical > Oh boy... TD4 problems...
Alexke
Belgium
Ok. i have my MY 2007 puma defender 4 years now!
already got an extra year warranty for all the problems:
Heated seat not working
Clutch was disintegrated
ABS TC Problems
EGR problems
etc...
And very rarely when I turn my key , the engine cranks 1 or 2 rotations and stops ...
This is SOOO annoying . and usually the car starts after i called the dealer :s , and they cant find a single DTC.
Also when I arrive at my destination , and turn the key and pull it out : The Land rover keeps running :S !
Its very awkward to hold your key while your engine is running . I also cant replicate this infront of the dealer!
its pretty random. and kinda dangerous.
ATM I am booked again for a DTC check ... and I am noticing that the dealer is starting to get annoyed...
What should I do? Big Cry
thanks in advance !! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #76002 15th Jun 2011 3:08pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
It's booooring, but have your mobile phone ready and record a video everytime you turn on the key .... one time it will be recorded .... then you can show it ... just a thought .... Idea Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #76003 15th Jun 2011 3:12pm
Alexke
Belgium
its like 1 in 1000 starts it does it Laughing
but I am running out of warranty... Sad
Also , my dealer is a stealer...
We bought 2RRC, 2P38�s and 2 New FFRR there also 2 TD5�s and my TD4! talking about brand loyalty.
Customer service ... yah right! Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #76005 15th Jun 2011 3:15pm
Barry
There may be 1000 reasons for the problem but I had the same problem with a Rover 420 ( company car and it does have rover in the title so don't throw insults Rolling with laughter )
It was a bad earth due to the paint not being removed under a contact after the front end was replaced. ( drove into the side of a bridge off a slip road , what I did to get rid of that car )
It is kinda funny when you take the key out , get ou and then realise the car is still running. 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone)
1997 Discovery ES Auto 300TDI (Traded in on a flat bed)
Post #76006 15th Jun 2011 3:27pm
110SEB
Wouldn't this awful problem point towards an ignition problem? Earth or otherwise?
Post #76097 15th Jun 2011 8:43pm
Lorryman100
Fuel pump stop solenoid would be the first thing I would be putting a multimeter onto next time it happens. Just in case it is a sticking solenoid or if not it would then give you a starting point to trace the fault back to the ignition module. And as you will have the connection off, give it a clean and a spray of ACF-50 to help conductivity.
Post #76146 16th Jun 2011 12:54am
