![]() | Home > Puma (Tdci) > Top end Clicking Ticking |
petercassidy Member Since: 20 Nov 2019 Location: Eastbourne Posts: 24 ![]() ![]() ![]() |
David, did you resolve this issue? Only ask as it seems similar to a noise mine has started making.
davidpalfreyman Member Since: 06 Oct 2010 Location: tanzania Posts: 67 ![]() ![]() |
Peter,
I did it resolve it, but not in the way I imagined. I ordered a new alternator pulley but meantime discovered that the 2 of the 3 rivets that hold the 2 pieces of the top idler pulley were missing. I removed the pulley, and split it in two to find that the bearing was inevitably worn out. Bought a bearing for about £2, put the pulley back together and the noise reduced. After a couple of days, no noise at all. I now have the alternator pulley but have not used it and everything is now OK 4 months on. If you want any more details, just ask David |
Thanks David that's very helpful
I'm not sure if the clicking is supposed to happen or not reading through different threads it was commented on as being "normal" when AC is turned on after startin the engine but it doesn't sound right to me.
That is how it started with mine, just when the AC was on and then the noise would stop when I turned the AC off. Then it started to make the noise all the time. Now for several months it is OK again.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
May I ask how you rejoined the two halves of the pulley? |
Yes, no problem. I used standard aluminium rivets again, but I am keeping an eye on them. The original ones were steel rivets, but they obviously didn't work very well as 2 of the 3 were missing
Dave |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
clicking on a ac unit is normal most cars you cannot hear it
Any chance of a photo where this please?
It is the pulley above the fan pulley to the left. between the fan and the AC pulley.
pullet number 2 on the diagram ![]() Click image to enlarge |
Great thanks, l have a close look at it tomorrow 👍
