Home > Puma (Tdci) > 2.4 will not start |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
Are you getting fuel to the infectors.? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
5th Dec 2019 10:34am |
Zixxer Member Since: 04 Dec 2019 Location: Tipperary Posts: 17 |
I tried to check that by disconnecting the little pipe that feeds the rail at the back towards the bulkhead and am only getting a little dribble of diesel when cranking her over
5th Dec 2019 11:23am |
This is the pipe I’m referring to - when turning her over only a dribble comes from it
5th Dec 2019 11:32am |
Trying to upload a pic but for some reason it’s not working - it’s the pipe at the back of the common rail
5th Dec 2019 11:33am |
this may help
Click image to enlarge Click image to enlarge |
5th Dec 2019 11:51am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2003 |
Fuel filter blocked? ....fuel pump not working?
5th Dec 2019 12:49pm |
number 1 on lower pic high presser feed from pump to common rail |
5th Dec 2019 1:26pm |
Diesel system looks fine getting plenty at the rail
Getting a P068A fault code and have checked all the relays under the seat a dozen times Going to try cleaning crank sensor now see if it’s stopping her running |
5th Dec 2019 5:31pm |
Getting a P068A fault code have read below
https://www.defender2.net/forum/topic18700.html?view=next |
5th Dec 2019 5:37pm |
Took out crank sensor tonight and cleaned it - wasn’t really dirty anyway, made no difference
When the computer was connected today the live data showed she would turn over at around 600rpm sometimes and nearly get running and if you try and start her again immediately after it only barely reaches 300. Leading me to believe the crank sensor might be faulty so I’m going to try put a new one in tomorrow I’m not sure how exactly you know the correct depth to insert the new sensor, but will try a new one to see if it makes any difference. |
5th Dec 2019 8:31pm |
you have two sensor one crank sensor and one camshaft position sensor
5th Dec 2019 9:18pm |
Yes I plan to change both tomorrow if I can get my hands on them
I will report back how I get on afterward Thanks for the help |
5th Dec 2019 9:35pm |
Crank sensor part number 6740819
Cam sensor part number 1358343 Both will be replaced tomorrow as they are reasonably small cost and easy replacement In the meantime I gave the ignition wiring a check to make sure nothing is loose I would have liked to get into the ecu mounted on the bulkhead inside the engine bay just to clean and check the connections but it looks caged inside some sort of box with shear bolts If changing the two sensors doesn’t do anything that’s where I’m headed next |
5th Dec 2019 9:40pm |
She’s alive again!
Cam shaft sensor - easy to get at, cheap replace and stopped my 2.4 dead Hope this thread is useful to someone in future - I was at my wits end with this, so if you find this thread don’t give up, you’ll get it |
6th Dec 2019 5:08pm |
