![]() | Home > Maintenance & Modifications > Recommendations for Anti-Seize products |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
If you want the good stuff, this is it.
https://www.rocol.com/products/stainless-steel-anti-seize But I just use copper slip, as it has many other uses and is cheap. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
I use this stuff. https://www.amazon.co.uk/Weicon-26100045-H...rds=weicon WARNING.
This post may contain sarcasm. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17916 ![]() ![]() ![]() |
I use Weicon paste whenever I have the misfortune to need to use stainless fasteners. It's very good stuff.
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 ![]() ![]() ![]() |
Perfect ordered a tub, thanks everyone!
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4318 ![]() ![]() ![]() |
I use ceramic brake grease, current tub in made by Granville. Not Arkwright's helper I don't think. 2007 110 TDCi Station Wagon XS
Interesting, some on here have seen the light.
![]() ![]() Ceramic grease then again is the best product for wheel hubs. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
I've always used copper slip but am going to start using the Molly grease I've just bought from Gwyn Lewis and see how that goes.
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
I use (have always used for the last 30+ years) copper grease for hubs / wheel nuts / wheel spindles - it has never failed to prevent them seizing. What makes ceramic better? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20948 ![]() ![]() |
Which type was it that came with the Naka SS bolt kits?
I have half a tube of that still and it’s lasted me literally years for my needs. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Berner.
They also sell tubs branded BMP. This also comes in small packets with other Nakatanenga fittings. I'm no expert but they all seem much of a muchness to me. However the Weicon was more readily available. WARNING. This post may contain sarcasm. |
Ceramic is totally metals free. So ideal for isolating a steel hub from an alloy wheel. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
But so is the Weicon? Don't remember what it says for Copaslip but the Weicon states: "Original sealed containers have a shelf life of 24 months." So, once opened it's good for how long? At the rate most DIYers go through a product like this, that must be most of the product either going in the bin or being used well outside it's design life. ![]() Last edited by Supacat on 5th Dec 2019 8:46am. Edited 1 time in total |
Hylomar blue might be your friend for this application. The original product was developed in conjunction with Rolls-Royce and was used for sealing aircraft engines. |
