![]() | Home > Off Topic > Things to look for when buying a freelander 2 |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1253 ![]() ![]() |
Hi. I have run two in the past, one I lost to a fire and the second eventually was px'd for my 110 USW. Overall a good car, wheel bearings can be very noisy and one or two independents were convinced it was a transmission problem. Have a look at this site for the lowdown
http://www.bellengineering.co.uk/fault-symptoms/ 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Great car, and reputation for reliability well-earned. Rear diff pinion bearing is a common issue but covered under warranty and clutches can be a bit weak but little else seems to go wrong with them.
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
^^^ what he said, even when replaced under warranty they still go again...
![]() Other key thing to look out for is cambelt & water pump replacement. Pre 2012 that was 10 year or equivalent mileage, post 2012 that was reduced to 7 years or equivelant mileage, not exactly sure why as the part numbers are the same for both vehicles... Apart from that service history & buy on condition. |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 735 ![]() ![]() ![]() |
Excellent, thanks all for the inputs guys, interestingly Bell engineering is only 15mins away from my parents place so that’s handy if I need anything serious done, can call by theirs for a coffee whilst the cars being done
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6700 ![]() ![]() ![]() |
Oooh if only we had a sister forum devoted to them?
www.freel2.com ![]() ![]() ![]() ![]() ![]() |
In this specific case they did a low level repair, which was the pinion shaft bearings alone as they deemed this sufficient at the time. It was out of warranty by about 3 years at that point I think so can't complain too much. If you're selling it on I might consider buying it back if it's in reasonable nick? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Fantastic cars, probably the best LR ever made in reliability. We did 147thou miles in ours before getting rid of it. It was an 08 reg and in the last year (2017) first set of front discs, battery, antiroll bar joints, and an intercooler hose. The only other problem we had with it was that the fuel tank is a saddle tank, so two sides, either side of prop, and the transfer pump, or it’s connections, failed, so we just run it from full to half tank before filling up again. So just be wary if buying one and thinking you’ve had a result by getting loads of free fuel with the deal.
We had an Alive remap on ours and it transformed it, much less gear changing, and huge improvement of mpg Andy. |
Thon - you have a PM
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2509 ![]() ![]() |
I own a 2007 XS Freelander 2 as a mile muncher/work hack/tip car
just done 800 miles in it last weekend to Paris and back performed faultlessly, cruised at 90-100leptons without any bother, 5 up with a full boot and still averaged over 31mpg best of all its done 230,000miles! ![]() ![]() not worth a great deal these days I imagine so ill just keep it as a faithful dogsbody ![]() 2015 Discovery 4.5 Black pack Firenze red XS |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 344 ![]() ![]() ![]() |
I had a freelander 2 for 8 years or so. 40k on the clock when I bought it & 120k when I traded it in.
I never had any problem with it at all & a great car to drive. Quite different to the puma I traded it in for which in the first year already needed a screen frame, blew its intercooler & emptied all its coolant through the heater return pipe. But no regrets. ![]() |
Great feedback guys, thanks!
I went to have a look at a couple this morning, both HSE, both immaculate for an 07 and a 10 plate, probably would have pulled the trigger on the 07 as it had relatively low miles and didn’t have a tan interior unlike every other HSE we’ve seen so far, unfortunately someone had already put a deposit on it. Got a couple more to see in the coming days too. |
