Home > Puma (Tdci) > Rear Door Stiff |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
work the door back and forth with WD40 on the hinges to see if it loosens
26th Nov 2019 11:28am |
Is it still stiff with the wheel removed? It could be worn or misaligned hinges. Darren
26th Nov 2019 11:49am |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
Seized hinge. I tried wd40 etc but until I took it off, ground the clip off, knocked it apart and lubed the hinge it was seized solid when off the car.
26th Nov 2019 9:48pm |
