Home > Maintenance & Modifications > Oil Temp Sender Thread size? Puma
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Hi folks;
Another question re fitting accessory gauges to my Defender Puma.
Does anyone know what adaptor I need to fit into the oil pressure port on the engine, so I can retain factory pressure info and fit a 1/4 oil temp probe?
? M10 ?
I purchased an SAAS 1/4 (Redarc oil temp sender) 1/8 mid port (factory oil pressure sender but 1/8 is too small so I need this size please) with 1/4 end thread.
I realise I can tell what size I need by disconnecting the factory sender and seeing if the 1/4 inch SAAS unit will fit the block, but If I can find out without spilling oil all over myself first (remember, open 1/8 mid port) I’d prefer to ask, and use what others recommend.
Thanks in advance and best wishes all.
Ken
Post #798579 17th Oct 2019 10:30pm
Martin
Site Admin
1/4"x18tpi NPTF  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #798632 18th Oct 2019 12:59pm
Baytown
Thank you.
Fantastic.
Thank you Martin.
I just need a 1/4 to 1/8 reducer for the centre port in the adaptor then.
Good on you.👍
Post #798722 19th Oct 2019 6:30am
Martin
Site Admin
Don’t you need a 1/4 - 1/4 - 1/4 t piece fitting?
Nothing you are trying to fit is 1/8 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #798733 19th Oct 2019 8:01am
Baytown
Hi mate.
No, as the threaded male end of the pictured fitting is 1/4 inch. It should fit the block.
The other end has the Redarc 1/4 inch temp sender fitted.
I need to fit a 1/4 inch to 1/8 reducer into the 1/8 centre port on the fitting so I can attach the factory 1/4 inch pressure sender.
Simples😗
Post #798739 19th Oct 2019 8:24am
Martin
Site Admin
You're quite right, I was thinking of it from the other end Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #798898 21st Oct 2019 11:10am
