Home > Puma (Tdci) > Puma TDCi problem
jasonshum
Hong Kong
Puma TDCi problem
We saw the same problem occur? Big Cry Big Cry Big Cry
Post #75264 10th Jun 2011 7:44pm
Zagato
No one else more knowledgeable (that's everyone!) has replied so I'll take a punt at it overheating and limiting the revs Confused
Post #75309 11th Jun 2011 8:14am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i have recently changed my fuel filter and that has made things run smoother, not sure if thats your problem, just a thought.
Post #75362 11th Jun 2011 1:35pm
Martin
Site Admin
What's happening? Confused Can't tell from just a video of the rev counter....!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #75363 11th Jun 2011 2:03pm
dgardel
Italy
should be:
1. mass meter
2. camshaft position sensor
3. engine rev sensor
4. fuel filter
5. what else?
- look if during the "problem" the VVT actuator is moving in the same manner
- try to disconnect the battery for 1 or 2 hours (ECU RESET) and then test again
- see with a voltmeter if the tension on the battery are fluctuating like the engine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #75364 11th Jun 2011 2:32pm
dgardel
Italy
up and down itself Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #75366 11th Jun 2011 2:34pm
MK
I bet for stuck EGR Puma 110" SW
Post #75369 11th Jun 2011 3:05pm
dgardel
Italy
MK wrote:
I bet for stuck EGR
Also should be..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #75379 11th Jun 2011 6:19pm
jasonshum
Hong Kong
But the problem is only in the open A / C air conditioning
Post #75517 12th Jun 2011 5:06pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Do you mean you only get this problem when the Air Con is ON Question Question Question
If that is the case then I would get the Air/Con system Pressure tested.
It could be that it is low on refrigerant or even over full and the Air/Con is switching on an off frequently thus altering the engine load frequently leading to the engine idle speed oscillating. Thumbs Up Thumbs Up
Post #75522 12th Jun 2011 5:29pm
Caterham
I suspect its the engine objecting to the music !!
sorry couldn't help that Rolling with laughter
Post #75562 12th Jun 2011 9:15pm
BigMike
Post #75672 13th Jun 2011 8:25pm
mse
alternator failing did that on a 300tdi disco i had Mike
Post #75685 13th Jun 2011 9:23pm
