![]() | Home > General & Technical (L663) > Detailed Photos |
JordanBefender Member Since: 29 Aug 2019 Location: York Posts: 16 ![]() ![]() |
just some interesting detailed photos , i've just seen. (press on the first photo to see the 100 photos)
https://www.caradvice.com.au/791472/2020-l...gineering/ Last edited by JordanBefender on 14th Oct 2019 4:44pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18032 ![]() ![]() ![]() |
No replacing the chassis on that when the rot sets in.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2701 ![]() ![]() ![]() |
Modern cars don’t rot, it’s depreciation vs cost of repairs and maintainence that is the killer .
Thinking about it, it would be great if Land Rover offered a body, suspension and interior option only. Then we could fit a 2.8 TGV or LS..... ![]() |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291 ![]() ![]() ![]() |
The 110 has about 1/2 the load space of my 110, will need the 130 I expect to match it NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
ids Member Since: 06 Jun 2019 Location: Forest of Dean Posts: 35 ![]() ![]() |
Some cracking photos in that set, got to be said. Good find. Interesting how the air intake runs. How on earth they get safe depth to 900mm depth is beyond me... |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3361 ![]() ![]() ![]() |
I thought the same. Presumably lifting it's suspension helps the wading depth.
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
define "modern". Disco3, Disco4 and L322 inner and outer sills are starting to become a "thing" at MOT time. ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Its mostly ali... |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1071 ![]() ![]() ![]() |
Possibly a dumb question:
The early pictures have no doors in place and no door pillar for the 2nd row door to hinge from. Maybe it's added later, but why does the rubber seal go all the way round the opening? |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
‘Elf and safety for the photographer in case he bangs his head on sharp steel edges while taking photos of the interior? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Hmm, look what happens to Defender aluminium alloy wherever it touches steel, and look forward to differential metal corrosion on a grand scale. I'm sure it won't happen, at least not in the warranty period. ![]() |
A look at a pre 2010 Jag XK/XK-R will show how modern ali cars still corrode. Same goes for the previous model XJ.
While paint processes were changed for 2010, I hear some later cars are starting to show the same issues as time passes. I got rid of my 2011 XK-R a couple of years back and there were a couple of questionable spots that I didn't look too closely at as I took the cheque from the buyer ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
