Home > Maintenance & Modifications > Clank
22900013A
Clank
Got a clank on my 90,000 mile 2011 110. When its warm there is a metallic clank as I take up drive in the higher gears. Tends to do it if I slow down and then speed up too. Doesn't always do it but seems to be getting worse. I noticed with the handbrake off the rear prop is rock solid but the front one I can turn quite a bit, but it doesn't move up and down. It seems to come from the gearbox area/front of vehicle.
Any ideas? The clutch feels normal and there is no noise or anything in normal running. Could it just be bad drive line slop? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #797968 13th Oct 2019 6:09pm
sako243
Prop behaviour is expected. The handbrake operates on the rear prop so you'll have some backlash in the centre diff which is why you can rotate the front prop.
Have you checked the A frame ball joint? Drive line knocks almost always appear to come from somewhere other than where they actually are. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #797975 13th Oct 2019 7:01pm
22900013A
I did checks on props with the handbrake off. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #797987 13th Oct 2019 8:14pm
22900013A
Totally lost drive today. Nothing even in diff lock. Guess it's either blown clutch or maybe layshaft?
I reckon my bank balance is about to take a dent anyway. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #798713 18th Oct 2019 10:57pm
Gearbox output adaptor shaft. Common (very, very common) problem, but cheaper by far than a layshaft.
Post #798714 18th Oct 2019 11:30pm
22900013A
Is that the bit between the gearbox and transfer box? I noticed at tickover there is a sort of grinding noise so wondered if it was clutch or somewhere at the front of the gearbox.
It is getting recovered to e h Douglas today so hopefully next week they will give me some ideas.
To top it all I've got issues with my IIA! So not a very good day overall. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #798725 19th Oct 2019 7:07am
Yes. Many threads on here about it.
Post #798747 19th Oct 2019 10:02am
22900013A
Well they agree with you. We have decided to fit an updated shaft from Ashcroft. Hopefully will be back with me late next week. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #798771 19th Oct 2019 1:38pm
