Home > Puma (Tdci) > DPF filter theft probability? |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 638 |
You need to lift the engine about 6 inches to get it out past the chassis rail so extremely unlikely!
4th Oct 2019 11:31am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3611 |
i don’t think diesels have Cats, just a DPF. No idea if there is palladium in a DPF though.
And what Scotm said, the get the DPF out is ridiculously hard on a def! |
4th Oct 2019 1:25pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3996 |
2.4s have a cat, no DPF. It doesn't look easy to steal, but I've probably jinxed it by saying that. It maybe that diesel cats are less desirable anyway due to dirtier gases going through them contaminating the contents. I understand that thieves like the newest cats possible as the cleaner they are, the more they are worth. 2007 110 TDCi Station Wagon XS
4th Oct 2019 5:12pm |
OP has a 2.2 so has both a cat and a dpf.
4th Oct 2019 5:15pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Looking at Land Rover Workshop and other Googled sites it seems the DPF and cat are in the same unit to meet EU5. While doing research there does seem to be lot of confusion about this.
Downpipe and Catalyst With DPF Stage 5 Plus 2.2 Diesel 2014 LR041312 an eye watering £1500 to £1800 |
4th Oct 2019 7:33pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2520 |
I was reading somewhere that PHEV's were mostly at risk as the cats do less work and so the materials are cleaner and hence worth more.
4th Oct 2019 8:36pm |
