Home > Td5 > DCPU rear load liner
Shuggy110
Scotland 2001 Defender 110 Td5 USW Stornoway Grey
I spent Sunday playing around with the 110 DCPU. I’ve been accumulating the bits for the conversion from a DCPU to a USW for about a year, using eBay and my local body shop to get take-off 110 CSW side panels filled etc.
I’d like to put in a rear load mat for the dogs. I can’t find one... any pointers please?
Anyway, job done. Gratuitous photo shots. They seem to be tiny but I don’t seem to be able to fix that!
Post #796605 3rd Oct 2019 10:07pm
I just used some rubber coin mat cut to fit (well approximately)
The additional mat with the upturned edges is a recycled Freelander rear cargo mat.
Post #796707 4th Oct 2019 5:00pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I used rubber flooring matt off Amazon:
2m x 1.2m | Fine Ribbed Rubber Garage Flooring Matting | 3mm Thick Floor Roll £29
It looks like the original Landrover matting.
Post #796709 4th Oct 2019 5:14pm
That would work 👍
However, the ribbed and even the 5 bar mats make sweeping out with a brush a real pain. OK if you what to lift the whole thing out and tip upside down but not so good if trying to leave I situ.
Post #796714 4th Oct 2019 5:28pm
boxoftricks
I've laid it down so the ribs are front to back not across so sweeps out fairly easily
Post #796715 4th Oct 2019 5:44pm
A man with a plan ~ I salute you Sir Thumbs Up
Post #796717 4th Oct 2019 5:54pm
boxoftricks
I did silent coat and foam covered with ply and the matt stuck down on the ply with a further loose matt on top. Nice and quiet now
Post #796720 4th Oct 2019 6:00pm
Shuggy110
Thanks - sounds good. I’ve got some insulation to put down so will buy some rubber roll from Amazon.
Post #796838 5th Oct 2019 7:50pm
Shuggy110
BTW, good looking dog!
Post #797758 11th Oct 2019 8:08pm
Thumbs Up
He's a bit bigger now and pretty much a constant companion 24/7. I now know the meaning of a velcro dog. Very Happy
Post #797858 12th Oct 2019 4:51pm
