Home > Technical > Strange heater issue on puma
bear100
Stumped with this one Confused
Travelling to the adventure over land show Friday, the further north I got the warmer it became, I put the heater to cold (air on is always on) but only the drivers side got cold the passenger air vents were still warm! The drivers side wasn’t really that cold either but significantly colder than the passenger side, turned the heater hot then cold but still a warm son in the passenger seat Shocked
What can cause this? I’m sure it’s been mentioned before but I can’t find it another post 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #795860 29th Sep 2019 7:44pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Probably the valve sticking on hot under the bonnet
Post #795862 29th Sep 2019 7:47pm
bear100
Hi Mick wouldn’t both sides be the same? 2023 Defender L663 V8
Post #795864 29th Sep 2019 7:54pm
ericvv
No, the Puma heater always provides more warmth to the left side than to the right side of the truck. That’s a heater matrix mis design issue. There is a LR fix for it, but that is a dash out job.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #795874 29th Sep 2019 8:04pm
bear100
Rolling Eyes not what I wanted to hear!
Any idea on the fix ericvv 2023 Defender L663 V8
Post #795879 29th Sep 2019 8:09pm
mick
Check the valve 1 st it’s easy
Post #795881 29th Sep 2019 8:11pm
bear100
Sorry mick what am I checking for, just googled a picture is there a leaver or switch on the valve I should check for movement?
Thumbs Up 2023 Defender L663 V8
Post #795882 29th Sep 2019 8:16pm
mick
https://www.defender2.net/forum/topic54969.html
This it’s on a cable the butterfly sticks
Post #795883 29th Sep 2019 8:27pm
ericvv
Here you go. Mind this is just the fix for the difference between left/right side heater output. Nothing to do with a stuck valve not allowing fully cold air.
Eric
https://www.defender2.net/gallery/albums/u..._fix~0.pdf You never actually own a Defender. You merely look after it for the next generation.
Post #795884 29th Sep 2019 8:33pm
bear100
Cheers mick Thumbs Up
Wow that’s hell of a job ericvv thanks for the link, I don’t think mine has that issue though it’s been fine for the last 9 years and just recently started, theres a big difference between the both sides, drivers is quite cold but the passenger side warm almost hot 🥵 2023 Defender L663 V8
Post #795886 29th Sep 2019 8:49pm
Eric
Be aware that this doesn't fix anything, it's a nasty (expensive) bodge which lessens the discrepancy. A custom cross-flow heater matrix would be the only solution.
Post #795922 29th Sep 2019 9:50pm
cold
I had a problem with the left side cold right side warm - the solution was a top up of aircon gas
Post #796061 30th Sep 2019 7:37pm
bear100
Thanks blackwolf Thumbs Up
Cold I is was thinking the same because the cold setting wasn’t really that cold and on some occasions you could see the cold vapour from the air vents when working correctly, which I haven’t for a while, I may try that first Idea It’s only around £30 for a re-gas
Post #796070 30th Sep 2019 8:18pm
