Home > Puma (Tdci) > A clunk and then feeling I had a flat - but havent?
cold
Any ideas here please?
Just takiing the family out , hadnt driven more than 1/2 mile when clunk and car starts shuddering in time
time with speed - thought I had a flat but havent so drove carefully home - any ideas on where to start?
Post #794519 22nd Sep 2019 6:24pm
Prop shaft UJ’s & Wheel bearings. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #794520 22nd Sep 2019 6:29pm
cold
Thanks Steve - not one for me then - will get to a specialist - any view on whether I should limp it there?
or will that cause more damage?
Post #794521 22nd Sep 2019 6:39pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
It does indeed sound like a wheel bearing but if I were you I’d jack up the corner that you think is the culprit and try rotating and rocking that wheel .
There are other possibilities but I’d have thought you’d be hearing some heavy clunking and crunching if it were a cv , halfshaft or diff ! https://www.instagram.com/hustynminepark/
Post #794525 22nd Sep 2019 7:00pm
cold
Thank you
Post #794526 22nd Sep 2019 7:22pm
jst
Something has come.e out of balance that rotates with road speed.
Wheel weights, prop weights?
Complete Failure of Shaft,cv, diff would need diff lock to drive. None of these or wheel bearings cause vibration in my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #794535 22nd Sep 2019 7:56pm
cold
Thanks jst, trying to get it in to the specialist tomorrow so will report back
Post #794546 22nd Sep 2019 8:11pm
When I had this once, it was not long after fording a stream in low level flood.
It likekh had water get into a UJ bearing cup, which I think the roller bearings disintegrated as were aged also and probably lacking grease.
It had the same symptoms as you had, then improved but not for long and got worse over a few months.
You couldn't tell the UJ cup had killed its self unless the prop was off.
MOT testing missed it, servicing checks missed it.
It caused a rear diff pinion oil leak many times and it wasn noticed and was only when it got really bad and I took the props off and articulated the joints was it found.
After I replaced them all. (What a job!) everything has been excellent and no more recurring diff pinion oil leak either.
The virbration was more severe at lower speeds, but was there at higher speeds too.
I could be barking up the wrong tree as it maybe something else but it's possible. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #794554 22nd Sep 2019 8:21pm
Could be a crownwheel breaking up.
Post #794599 22nd Sep 2019 9:47pm
