Home > In Car Electronics > Lazer light bar wiring kit, quick question! |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2839 |
Fitted the R28 52” today which comes with a wiring kit and which is switched. I want the light with main beam, only if the switch is on so do I just clip the feed to the switch from the relay/battery and connect to main beam wire? It’s the diagram at the bottom.
Cheers Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
12th Sep 2019 7:37pm |
deep down Member Since: 02 May 2012 Location: France Posts: 204 |
Yes you're correct, there is no need for the feed from the battery.
Just take the feed from the main beam, to the switch, then to terminal 85 on the relay. |
12th Sep 2019 9:31pm |
