Home > Maintenance & Modifications > Front discs vented vs non vented
ibexman
Hi guys I’m about to overhaul front swivel seals any may upgrade while I’m there to vented discs
Has anyone done this and noticed a real difference cheers Chris
Post #792594 12th Sep 2019 7:37pm
grafty99
The only difference is fade resistance. They keep cooler for longer under sustained or repeated heavy breaking. Especially effective if towing or loaded Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #792602 12th Sep 2019 8:05pm
The vented also help if you run bigger tyres (like 255/85) as the extra diameter really makes a difference.... when I swapped an old 90 over to vented and was up laning in Wales, giving it "the beans" when out on the road bits, it really helped stop brake fade.
Post #792622 12th Sep 2019 9:07pm
Worth the little extra cost Thumbs Up QRZ 2e0vpf
Post #792643 12th Sep 2019 10:30pm
