Home > Td5 > Diff and transfer case oil
excossack
Time to change the oils. Front / Rear diff and transfer case Gear Oil SX75W-90 GL-5 Semi Synthetic OK for the job? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #792096 11th Sep 2019 1:31pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
GL-4 i think is what recommended, but most say GL-5 is ok too.
Post #792124 11th Sep 2019 2:44pm
4RF RDS
Re: Diff and transfer case oil
GL4 is spec. If its never had synth before sythn and semi synth can hasten leaking at seals. Good luck Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #792131 11th Sep 2019 3:53pm
excossack
Cheers, I am not 100% sure what synth I have used in the past.(short of digging out previous receipts) 1999 Defender TD5 110
Regards
John M0VAZ
Post #792133 11th Sep 2019 3:57pm
bankz5152
EP 90 Mineral Oil is the only thing that should go in diffs cvs and tx boxs
Post #792195 11th Sep 2019 7:10pm
excossack
Found the old containers in the shed;
SX75w/90 GL4 Gear oil
EP80/90 GL4 Hypoid gear oil 1999 Defender TD5 110
Regards
John M0VAZ
Post #792200 11th Sep 2019 7:27pm
dorsetsmith
Post #792202 11th Sep 2019 7:29pm
4RF RDS
[quote="bankz5152"]EP 90 Mineral Oil is the only thing that should go in diffs cvs and tx boxs[/quote
Agreed unless of course you have a Roamerdrive Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #792221 11th Sep 2019 8:35pm
excossack
So....... One says EP90 for both. One says EP90 for axles, and 75w/90 GL5 for transfer case! 1999 Defender TD5 110
Regards
John M0VAZ
Post #792227 11th Sep 2019 8:53pm
landy andy
75-90 in mine and fully synthetic. I wouldn’t run mineral in a transfer box.
Post #792233 11th Sep 2019 9:01pm
excossack
75/90 and EP80 ordered for the job. Along with engine oil and filters plus gear box oil. 1999 Defender TD5 110
Regards
John M0VAZ
Post #792908 13th Sep 2019 9:13pm
miker
Ep 80/90 GL4 in mine, front back and transfer case.
All done 220k and seems fine!
Post #792947 14th Sep 2019 12:40am
