![]() | Home > Maintenance & Modifications > Td5 dash upgrade |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
I put a later TD5 dash into my 1999 300, fairly straight forward, esp if you don't use the later instruments but they can be connected up if you have the know how and certainly give better illumination, particually like the illuminated heater decals.
Re seats, if you want OEM switches controling the heater elements on later seats you will need to source a loom or just add after market pads to your existing seats, use the included loom and change over the switches (think I remember someone posting a wireing diagram on here some time ago). Got my dash after a long ebay wait. |
StephenTD5 Member Since: 04 Sep 2019 Location: Berkshire Posts: 39 ![]() ![]() ![]() |
Ok cheers so it's doable, if I can find a dash...
& I can't imagine original ones come up too often. There's no britpart alternative? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Yes, Britpart do a self assembly dash kit.........
![]() Click image to enlarge ![]() ![]() |
