Home > Puma (Tdci) > Supplier Far Corners: any recent contact? |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 51 |
I'm wondering if anyone has successfully made contact with Far Corners, a UK-based supplier of various LR aftermarket add-ons: https://farcorners.co.uk/ They have a couple of nice Puma bits I'd like to pick up, but I've not been able to get an email reply, either via their contact form or direct email. I'm Australia-based, so need to "talk" to them to get a shipping quote before ordering.
Any recent experience in contacting them amongst the forum community? Are they still trading? Thanks in advance! |
5th Sep 2019 8:11am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Hello
I contacted them via the facebook page 'Far Corners' I was after the rear seat extenders, then started e-mailing. Sam Sorted my order very quickly and was delivered super quick. Here is the e-mail contact I had called Sam sam@farcorners.co.uk Good luck |
5th Sep 2019 9:55am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4788 |
Roy5695 has used them and they have been good to deal with 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
5th Sep 2019 11:13am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
Several posts on here about them.
Product is good, if not initially fully tested, I think they work on principle of first customers pointing out any issues, same as lr. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
6th Sep 2019 7:09am |
Hello
The kids have a bit more room as it moves the angle of the back part of the seat so they are happy. They do not sit as upright. I didn't fit them mind so not sure on the job, the garage did it for me when my car was in for a service and some other bits |
6th Sep 2019 8:34am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
Kris at Far Corners is a lovely guy and very enthusiastic about what he does, but communication can be terrible. Keep trying they do some great products. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
6th Sep 2019 11:13am |
Ok: contact made, parts ordered! Will update with my thoughts once fitted. Thanks again for all the replies.
7th Sep 2019 12:29am |
...And now, seat risers received and installed. The ordering and shipping process was reasonably OK once contact was established.
The fitting process is fairly straight-forward. Instructions are rudimentary, but once you have the parts & car in front of you, it's pretty self-explanatory. One thing that I think the instructions did leave out is that you need to remove a threaded stud from the "old" assembly, to be replaced with a bolt from the kit. Again, once you're into the task, it's obvious and not hard to do. And, it looks like the kit used to include self-adhesive rubber pads to pad out the rubber stops, but now includes rubber rings that pack under the rubber stops to achieve the same end. Not whingeing, just trying to leave some hints for anyone who goes the same route. And, to be clear, the kit was entirely complete & self-contained. Note that while I was able to do the "single" seat on my own, the weight and bulk of the "double" seat had me getting assistance when manoeuvring it around - the instructions quite correctly recommend this. Total time fitting a bit under 2 hours, tops, at a leisurely pace. So, they're in, and the slightly more reclined seating position feels good. It does put occupants closer to the C-pillar as a trade-off; will have to load the car up with bodies and see how they find it. Note that this proximity to the pillar would probably not be noticed by younger/smaller passengers. Also, the edge of the seats now brush against various trim fittings when folding & unfolding - not a biggie, you just go slow & careful when doing so. Never a bad idea anyhow. Bottom line so far, does what it says on the pack, recommended. |
28th Sep 2019 5:16am |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2045 |
any pix of the install??
28th Sep 2019 7:42am |
Sorry, no, but what you end up with is pretty much what you see on the Far Corners web site.
I'll take some of the areas I spoke about in particular over the next few days, ie trim rubbing & the rubber spacers. |
28th Sep 2019 8:17am |
