Home > Tdi > Oil filter coming loose.
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
3rd time this has happened. I really make sure it's thight when I service her.
But after a few months I find a drop of oil. And when I check the oil filter it's loose..
After that it's usually okay but now I lock it with wire.
Someone said that it could be the specific filter I use, I use Mahle.
Any input will be appreciated.
Post #790003 2nd Sep 2019 7:20am
Mo Murphy
Interesting. I noticed my oil filter had some dribbles down it a couple of weeks ago. Tightened a little. It is indeed a Mahle filter.
50 Shades of Pennine Grey
Post #790013 2nd Sep 2019 8:15am
Litch
Really basic thing which I am sure you are doing but...…….
Are you wiping a smear of oil around the seal before screwing the filter into place?
If not the seal could be "grabbing" at the dry surface and then later (when some oil has got onto the seal) allowing the filter to leak slightly as the seal isn't tight?
Granny to suck eggs and all that. Wink ONE LIFE, GET IT!
Post #790116 2nd Sep 2019 5:56pm
jfh
Jip. Made sure about it.
Post #790165 3rd Sep 2019 5:42am
