Home > Tdi > 200tdi lt77 gearbox fitted to 300tdi engine |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
If it’s in a defender, doesn’t a disco box have the gearstick too far back?
30th Aug 2019 8:00am |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
to fit an R380 to a 200tdi you need a 'stumpy' bell-housing that's shorter.
Going the other way with fitting an LT77 to 300tdi I don't know, but why would you, it's a downgrade. Ashcrofts whould know the answer |
30th Aug 2019 9:59am |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Discovery"s have the long bell housing and pinion shaft, thats why the gearstick is back near driver, i had an Lt 77 fitted to a 300tdi. so splines must be same, just check brfore you fit, , i have also put a Discovery LT380 IN A DEFENDER, you have to change the front shaft & bellhousing, to the shorter defender one , thats a box split jobby.
30th Aug 2019 9:43pm |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 311 |
I think some additional info on what you’re wanting to do with the engine/gearbox combo would be helpful.
A few quick answers for the meantime… Will the LT77 fit the 300tdi? Yes, it will be a direct fit. Will it fit straight in a defender? No, as has been mentioned the disco gearstick is in a further back location on the gearbox, among other complications depending on current engine/gbox. |
2nd Sep 2019 5:41pm |
