Home > Puma (Tdci) > Front Drivers seatbelt
216lcg
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Can anyone recommend a supplier for a drivers side front seatbelt? After years of catching mine when i slam the door it finally gave up the ghost as far as this year MOT was concerned. Was quoted about £180 from Landrover which seems a little over the top! 2007 puma 90. Had a quick look on eBay and nothing there. Thanks L
Post #788419 23rd Aug 2019 9:53pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Maybe try Bearmach. They are doing 15% off their products at the moment.
Post #788420 23rd Aug 2019 9:57pm
216lcg
Thanks. Just looked on line and they are out of stock!
Post #788422 23rd Aug 2019 10:10pm
Zed
Post #788424 23rd Aug 2019 10:27pm
216lcg
Alas no. Chassis number tarts with a 7. I think this is the td5 version. I need the revised puma model with chassis number starting with a 7. Apparently the belts or fixing points are different
Post #788442 24th Aug 2019 8:39am
cold
If it is just the webbing you could have that replaced? I am in the process of considering this for mine and the cost is about £40ish per belt - speak to sue@fdts-seatbelts.co.uk (no connection or affiliation) - she is the one I am in dialogue with and they can do a quick turnaround
Post #788444 24th Aug 2019 8:44am
216lcg
That is a good idea. Any idea how quickly it could be done?
Post #788447 24th Aug 2019 8:49am
216lcg
Next question: How easily is the belt to remove. Is it just a matter of putting a socket on 3 bolts?
Post #788449 24th Aug 2019 8:55am
cold
Re leadtime then they are based in Surrey and can do same day with appointment or 3 day turnaround (on receipt) if posted - regarding how easy to remove I havent got that far and was going to search the forum and see if there are any issues with just undoing the bolts
i.e. was something going to drop off the other side if I undid them
Post #788456 24th Aug 2019 10:01am
216lcg
Excellent. I sent an email. Will update on result.
Post #788463 24th Aug 2019 10:58am
cold
Here is their website - Sue seemed really helpful
http://www.fdts-seatbelts.co.uk/
Post #788464 24th Aug 2019 11:04am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Highly recommend FDTS - I replaced the webbing on my 90 - fancied a colour to match the Landy and they send a dozen samples to choose the correct Red Thumbs Up
Post #788465 24th Aug 2019 11:15am
caterham6
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Even get your old belts back top service
Post #788501 24th Aug 2019 9:02pm
NickMc
Yeah not too bad, I’d soak the fixings in WD40 or the likes for a while if you have the time. Don’t lose the top belt bolts and spacers they’re very expensive to buy new.
Post #788502 24th Aug 2019 9:24pm
216lcg
I can not recommend FDTS enough. I posted my belt off on Tuesday, received by them the next day, repaired, despatched the same day and with me by 2pm in Thursday. My belt had consistently been chewed by the day catch on just the last 30cm so there was enough webbing left to just cut off the damaged section and re-sew. I had been quoted £32 to replace the webbing and fully expected to be charged this but the cost for sealing and seeing the end was just £8. Much better than the near £200 quoted by LR for a replacement. Removing/ refitting is 5 minutes only. I can’t recommend FDTS enough and highly recommend them: info&fdts-seatbelts.co.uk www.fdts-seatbelts.co.uk tel 01932 342043
Post #789344 29th Aug 2019 2:41pm
