![]() | Home > Td5 > Injector seals - engine damage? |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 ![]() ![]() ![]() |
As an update, rather than try to start this morning I first purged the fuel system... it started first turn of the key instantly like it normally does... and appeared to be running on all 5 cylinders...
Does this still point to leaky injector seal(s)? Faulty fuel return valve? Thanks, Stig |
fuel filter head in good order
![]() https://www.lrworkshop.com/diagrams/land-r...tors_53509 |
![]() Click image to enlarge Seems to be... Also, video of her starting today after I purged the fuel system... https://youtu.be/yNTsIqKyrIo |
But could be the return valve... I'm reluctant to start taking things apart while 350 miles and a ferry journey away from home.... |
![]() Click image to enlarge when your removing fuel lines adaptor to replace none return valve you find out how good filter head is brass and aluminium , copper and steel good recipe for corrosion ![]() Click image to enlarge |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
99.9% certain it will be the injector seals. Has your oil level gone up or does the oil smell strongly of diesel. If not I dont see an issue with driving 350miles.
When the leak is still minor you will get combustion gasses into the diesel rather than diesel into the oil. The worst that happens with combustion gas into the diesel is you will start getting debris in the fuel return system. I have driven my Td5 for many miles with the injector seals gone. Mine goes fairly frequently (every 12-18months) on one cylinder due to an issue with one of the injectors. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Bizarrely the last few mornings it's back to normal, no problem starting... is this normally an intermittent problem at first?
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
When mine had same symptoms it was the injector seals. My advice is go genuine!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5985 ![]() ![]() |
No. Not in my experience. Once it starts to be a problem it only gets worse. That is with same scenario, so every morning for example. Obviously the longer you leave it for the harder it is to start, without priming system first. I would be surprised if they have failed so soon, unless done wrongly, which I find hard to believe on a new head. |
Is misfiring a sign of bad seals?
I noticed last night after my lift home that she is firing on less than 5 cylinders... wondering if this is related or a sign of a different problem... Thanks |
No, possibly oil in the red ECU plug.
Injector seals is normally bad starting only. Not misfire once started and running.
Thanks chaps... I'll start with the ECU loom and work from there...
