![]() | Home > Maintenance & Modifications > Bent bonnet hinge bracket. I am a total *#@%!!! |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Ouch - you have my sympathy. So easily done.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
That’s so annoying, but don’t let it spoil your ownership. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3648 ![]() ![]() ![]() |
I know that feeling.....
What a P.I.T.A. ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
Right, I’ve calmed down a bit now. Is this something that anyone else has ever done, or is this a first? I need to figure a way to bend it back without damaging anything else in the process. 2007 110 TDCi Station Wagon XS
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
Have you a photo DEFENDER 90 TDCI XS,
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
Same thing happened to me on the passenger side I noticed paint flaking off on the bonnet we've been touching the wing I wonder what it was until I noticed a little bit of a gap behind the hinge
Here some pictures off mine is there a fix
![]() Click image to enlarge ![]() Click image to enlarge |
^ it maybe worth replacing the plastic / rubber Bush in the hinge these do wear and that maybe the cause
![]() 2008 SVX 90 2000 XS TD5 90 |
Mine is bent exactly like your Sulisuli. I was changing the bushes when I bent it I think
![]() Have you fixed it? 2007 110 TDCi Station Wagon XS |
Bluest I don’t have the bent hinge, it was fatboyron. I changed my hinges for Optimill ones. 2015 HT XS 90
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Are your bushes in the wrong way round? (The cut out is offset) they do look a little tired anyway ![]() |
Jubilations! I fixed it. Fortunately, the brake servo mounting structure, where the chassis plate is, is a pretty solid piece. So I levered off there. Had to put a bar in the hinge so it sort of rolled round it. All back where it should be now.
![]() Click image to enlarge 2007 110 TDCi Station Wagon XS |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2286 ![]() ![]() ![]() |
Nice one
Good work, pleased it’s back where it should be
