Home > Off Topic > Ring Flash for Canon cameras
leeds
Any recommendations for a ring flash for Canon cameras?
Any advice on use of ring flash etc appreciated
Brendan
Post #74053 3rd Jun 2011 8:51pm
Wizard Sleeve
United Kingdom 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Depends what you want it for Macro or Portrait work for the eye reflections?
Post #74066 3rd Jun 2011 9:16pm
leeds
Basically so I can take better photos without shadows of gear for our website so suppose it would be macro.
Brendan
Post #74068 3rd Jun 2011 9:33pm
Wizard Sleeve
Generally the camera manufacturers ring Flashes are the most convenient for this kind of stuff. I'm a nikon owner and have a nikon ring flash. There are always cheaper options out there from other manufacturers but generally the canon one will suit your needs better. When I've bought flashes from other manufacturers in the past it usually involves a lot more setup each time you want to use the thing which eventually, if u use it a lot will put you off using it. I have several nikon flashes and you just plug them in (or wireless) and they just work. The only thing with after Market flashes is if you spend the money you can get a lot more power.
Post #74076 3rd Jun 2011 10:00pm
