Home > Puma (Tdci) > DIY winch bumper
diduan
Bulgaria
DIY winch bumper
After a van with tourists crashed into my front I decided to make my own front bumper and mount a winch to it. The goal was to make it as close to stock as possible, but stronger.
Here is where I started.
After fixing most things it was time for the wimch bumper.
I had some 5mm sheet metal left from my other offroad vehicle. So I decided to use it. First I made a plate to position the winch in its place.
Then i had to make the side parts - left and right and weld them to the center section.
The original mounting points were really difficult, because of the blind threads on the bottom of the bumper. It took me one whole day just to make it work. I used thr factory thread plates and welded them to the bumper.
Additional support here, close to the towing points.
Some amateur paint job using spray cans here.
After four days eating dust this is the final version.
I wanted the relais box to be on the winch. If you detach it, the winch can be mounted even more compact.
Now I have a winch, but it is not connected yet, so I am officially a poser. Cool Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #784639 3rd Aug 2019 8:58am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Thumbs Up
Post #784640 3rd Aug 2019 9:03am
Goat Peter
Great job.
Post #785365 6th Aug 2019 11:41pm
Co1
Top work! Thumbs Up
Post #785378 7th Aug 2019 6:16am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Good solid bumper Thumbs Up
Post #785380 7th Aug 2019 6:37am
CarMan
Bow down Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #785385 7th Aug 2019 7:11am
