Home > Tdi > rear wash wire
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
rear wash wire
I am trying to wire up my rear washer I have the switch and all wired up on the dash ,but cant find the wiring in the rear corner .
Could they not be wired to the rear ,just to 1 of the 3 connector blocks that are just below the air box ?
Post #783656 28th Jul 2019 7:56pm
oneten110
If your vehicle was built as a utility it is entirely possible that the harness fitted at the factory does not include the wires for rear smear or heated rear window.
Don't see any problems with fitting and routing your own wiring to the rear wash.
That said, the rear washer pump is typically fitted to the tank in the engine bay and the hose routed from there, into the cabin, up the windscreen pillar and along the roof gutter to the jet at the back
It was only on the early vehicles that land Rover fitted the plastic bag in the back door as a reservoir for the rear wash. It is not a Defender, it is a One_Ten
Post #786115 10th Aug 2019 3:05pm
tolley
Many thanks for the information Thumbs Up
Post #786281 11th Aug 2019 4:01pm
