![]() | Home > Maintenance & Modifications > Which make brake pads?? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
Genuine. Yes they are made by someone else but who? All others appear to squeal on mine. Genuine don’t, and come with proper fitting kit.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Mintex
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
I’ve had good success from Pagid on the last 4 changes I’ve made - admittedly all different marques, BMW, Ford, Saab & Peugeot. But I’ll be using them again. Always good quality.
I recently fitted a set of Borg and Beck pads to the rear axle of my 110 and they seem absolutely fine. Purchased from my local motor factors. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 21st Jul 2019 8:15am. Edited 1 time in total |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 735 ![]() ![]() ![]() |
Mines the same as landy Andy, everything but genuine seems to squeal. Probably the more expensive option, but the squealing was driving me mad!
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
Ferrodo with Ceramic brake grease (dunno if it helps just good practice) and I don't have brake squeal and it performs just as well as it did with genuine.
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
As above , just fitted ferrodo all round . Brakes very well and not a squeak . I actually didn’t copper slip the backs as I was told that the gel layer that the pads already have built in would suffice . So far so good https://www.instagram.com/hustynminepark/
I buy the cheapest I can get. No squeel at all. Yes they don't last as long but also the genuine one will wear fast in wet sand. Half a block thickness in one day is common without abs and tc.
So I rather replace a little more often then spend loads of money. ![]() I know most of you will disagree. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2394 ![]() ![]() ![]() |
Ferodo make the genuine pads.
I use mintex, for me they are the best combination of quality and value for money. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I fitted some on my 2014 110 supplied by Euro Car Parts via eBay earlier this year for all four corners and they've been fine. I think they were Pagid (certainly not some unbranded ones) but they weren't very expensive. And no squeals.
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I tend to use Delphi (AP Lockheed) as they come with anti rattle shins and have no problem with them.
I will not fit another set of Mintex pads again. They just squeal! Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6706 ![]() ![]() ![]() |
The factory fit ones in my 2.2 squeal a lot
![]() Buy a quality branded pad, LR don't make pads. ![]() ![]() |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Thanks everyone, think I’ll try Ferodo pads this time and see how I get on with them, the genuine pads I’ve currently got have squealed from new anyway! 15 plate 2.2SW XS
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 ![]() ![]() ![]() |
Just out of curiosity are the front and rear brake pads for a Defender 90 the same ?
