![]() | Home > Puma (Tdci) > Addin Central lock to basic unit |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 ![]() ![]() |
![]() Click image to enlarge MAYBE OF HELP ![]() Click image to enlarge |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
On my 2007 110, the alarm unit was the same as a central locking version, but the relay was not fitted to the circuit board. Either remote mount an aftermarket version or get a 10As from an early disco and cannibalise it.
https://www.ebay.co.uk/itm/Central-Locking...33bae8e75d |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Don't think this applies to the later black 10AS-clone.
You can retrofit the correct relay into a non-central locking 10AS. ![]() ![]() |
Thanks Martin, I didn't realise LR had gone to the trouble of replacing the genuine 10AS with obviously a much better, theft proof alarm system...…!
Keith |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Front windows were easy enough, but britpart needs to up their game and supply switches that use the same connectors as stock.
Rear windows were easy from LRI central lock i cheated for now, got the omega DS-kit-4.4 where if you lock either the driver or passenger door it will lock the car. but still want a remote controlled signal so its seemless. Mystery, thanks for the image, PM sent Can't leave well enough alone |
this may be of interest https://www.technozen-electronics.co.uk/la...-services/
Thats the older unit.
Thanx though Can't leave well enough alone |
