Home > Off Topic > Recommend Mail Order Steel Laser/Water Cutting Company
hank
I am looking to get a a single item cut from around 3mm mild steel. The piece fits within 200mm square
I have googled and contacted precision-profiles and laserprocess but neither replied. Guess a single small piece is not worth their time, so looking for recommendations from experience of such work? I intend to provide a cad file > 110 XS Double Cab
Post #781860 17th Jul 2019 1:28pm
rallysteve
I believe there are some ebay sellers advertising the service if you send them a .dwg/.dxf file of the part. We had some stuff waterjet cut for the rollcage mounting brackets and it was hard to find a company who were willing to do a single item for cash payment. They are all set up for larger orders on account.
Cheers,
Post #781861 17th Jul 2019 1:30pm
hank
Magic I will take a look Thumbs Up > 110 XS Double Cab
Post #781862 17th Jul 2019 1:30pm
AJC
I have a plasma cutter, it may not be accurate enough for what you want though. if you can load an image of what it is you want I could help?
Post #781863 17th Jul 2019 1:41pm
hank
Ooooh Bow down Will PM > 110 XS Double Cab
Post #781866 17th Jul 2019 1:50pm
Bluest
If AJC can’t help, I would suggest finding your nearest place and walking in off the street. I worked for a profiling firm with two big lasers, and small jobs like that are not worth messing about with, but if you walk in with a good CAD file and some cash you will likely to get someone who will help you out. 2007 110 TDCi Station Wagon XS
Post #781872 17th Jul 2019 2:10pm
hank
Yeah I get where you're coming from but I'm away working in the Middle East and wanted the part ready when I visit home for annual leave > 110 XS Double Cab
Post #781879 17th Jul 2019 3:14pm
hank
rallysteve, my ebay skills have let me down here. Would you share the listing you used? > 110 XS Double Cab
Post #781880 17th Jul 2019 3:14pm
90 Dreamer
i found a couple of listings with the search "water jet cutting" - probably others
https://www.ebay.co.uk/itm/Waterjet-Cuttin...SwMvdc~5ok
https://www.ebay.co.uk/itm/Aluminium-Water...SwnAddFe6I
Post #781885 17th Jul 2019 4:12pm
hank
Yeah found them. One is stainless and the other aluminium but I’m after mild steel Big Cry > 110 XS Double Cab
Post #781887 17th Jul 2019 4:21pm
rallysteve
I used a local company through a work connection in the end but had to go through setting up a dummy account etc.
http://www.controlwaterjet.co.uk/ in case you want to try them.
There are a few if you have a dig through the listings. I have found a few through 'plasma cutting service' and 'laser cutting service' as search phrases.
Cheers,
Post #781888 17th Jul 2019 4:29pm
