Home > Maintenance & Modifications > Wiring Up Daytime Running Lights to my Defender 90
boardstein
Hi
Could someone help please, I have today received a new bumper with daytime running lights, there are no wiring instructions, and the supplier has said i need to to wire them to the ignition wire, which is green and white, could anyone help in informing me where this is and is it easy to add a wire to it. many thanks
Post #781369 13th Jul 2019 7:41pm
Nadine90
Wales 1986 Defender 90 300 Tdi CSW Fuji White
what lights are they ? are they Ring ones ?
Post #781371 13th Jul 2019 7:48pm
boardstein
No, They dont have a brand name on them
Post #781373 13th Jul 2019 7:49pm
Nadine90
i know the ring ones wire up to the battery and the ground and to side lights so when you put on the side lights the drls will dim.
Post #781374 13th Jul 2019 7:53pm
boardstein
Thank you Nadine, Ive tried that, but then the lights are on, even when the ignition is switched off
Post #781376 13th Jul 2019 7:58pm
Nadine90
may need to wire up to ignition live feel then ground and side lights then.
Post #781378 13th Jul 2019 8:01pm
Mo Murphy
1. Take an ignition switched supply
2. Put it through a normally closed relay to the DRLs
3. Tap into the side light supply and take the wire to the relay to open it when side lights are turned on.
Hey presto, dimming DRLs
HTH
50 Shades of Pennine Grey
Post #781383 13th Jul 2019 9:15pm
boardstein
Mo and Nadine, thank you, that makes a lot of sense, last question how do i find and tap into the ignition live feed? many thanks
Post #781432 14th Jul 2019 10:54am
MartinK
boardstein
the one I have used in the past is the white/orange wire to the back of the radio in the dashboard
this thread will help https://www.defender2.net/forum/topic5492....=checktemp Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #781533 15th Jul 2019 8:24am
Martin
Site Admin
That's not a true ignition feed, it cuts out when the starter is turned and then comes back on.
White/green is ignition. Found on most of the dash switches.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #781540 15th Jul 2019 10:02am
boardstein
Martin and Martink, thanks guys will go through this tomorrow
Post #781635 15th Jul 2019 10:35pm
boardstein
Hi guys
Do DRL have to dim when the side lights are on, as I did not bother with the side lighter connection and then come on when the ignition is turned on and stay on when side lights are on, but no dimming?
Post #781736 16th Jul 2019 7:36pm
Mo Murphy
Yes they do.
Post #781776 16th Jul 2019 9:48pm
discomog
They should either dim as Mo says or they should extinguish when side lights are switched on. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #781788 16th Jul 2019 10:13pm
boardstein
Thank you, this is very helpful
Post #781832 17th Jul 2019 8:11am
