Home > For Sale & Wanted > SOLD Land Rover Discovery Landmark TD5
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi my friend Jad is selling his Land Rover Discovery due to needing an automatic now, he keeps his cars well maintained and if it requires any work he gets it done, it’s a
2.5 Td5 Landmark 5d (7 Seat) 2004/04 with full Leather interior and Dual Climate Control
• 125,000 miles
• Full service at 118,000 miles. Included new coolant and replaced gearbox and diff oils
• New exhaust manifold at 120,607 miles
• New Borg & Beck clutch, Valeo dual mass flywheel and slave cylinder at 121,785 miles
• New genuine Fuel Pump, gasket and 5 x injector seals at 123,800 miles
• New lower ball joints & o/s front antiroll-bar link at 124,008. Some welding on o/s front shock mount
• MOT until 19/06/2020 No advisories
• Good condition, but expect age related marks (nothing glaring)
• Working twin sunroofs (no leaks)!
• Driver side electric window needs attention!
• Reluctant sale but I need to get something with an automatic gearbox!
• £4250 ono Located near Thame in Oxfordshire
Cheers Paul ( Jad 07775 782386 )
Post #781343 13th Jul 2019 2:41pm
Barneyboy
More pics
Post #781344 13th Jul 2019 2:46pm
VVS210
Do you know if this has a diff lock please?
Photos suggest the transfer lever doesn't move side to side but diff lock may still be fitted to transfer box on a car this age - need to crawl under it to find out though...
thanks.
Post #781396 14th Jul 2019 6:40am
Barneyboy
Hi VVS210 I’m not sure in answer to this I’ve got a closer picture of the transfer lever and as you’ve mentioned it appears to go forward and back but not sidewards, are you saying that it could of been fitted by the owner or it was an optional/ factory fit item Thumbs Up
Cheers Paul
Post #781398 14th Jul 2019 7:16am
Barneyboy
Hi this has traction control and no diff lock fitted as the diff lock light is not lighting up on the dash when turning the ignition on.
Cheers Paul Thumbs Up
Post #781422 14th Jul 2019 9:58am
VVS210
Thanks Paul.
Post #781470 14th Jul 2019 5:46pm
It may (or may not) have the difflock mechanism in the transfer box, you'd have to check for the operating spigot on top of the front output housing. If it has this, it would be very easy to upgrade the lever. If no spigot, the transfer box would need upgrading.
Post #781473 14th Jul 2019 6:06pm
Barneyboy
Hi VVS210 no problem Thumbs Up
Hi blackwolf I’m guessing thats what VVS210 was saying about getting underneath to find out Thumbs Up is it easy enough to spot or is it easily missed please, cheers Paul
Post #781476 14th Jul 2019 6:31pm
htb2
Wales
Reach up and feel for the selector shaft sticking up at front of transfer box, feels about the size of an M8 bolt. It is behind and above the the front output flange.
Mine does not have it fitted.
Post #781479 14th Jul 2019 7:32pm
Barneyboy
Cheers htb2 Thumbs Up here’s some pictures Jad has taken yesterday evening Thumbs Up
Cheers Paul
Post #781516 15th Jul 2019 6:07am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I thought all the last discovery 2's had diff lock? My dad's 53 plate one definitely has, however that's an ES premium auto so maybe it depended on spec?
Post #781529 15th Jul 2019 8:13am
htb2
Wales
Yours is like mine, no provision for a manual difflock there.
Post #781543 15th Jul 2019 10:22am
Definitely no difflock on that one, note the absence of the operating spigot in the area marked below. You would have to fit the front housing and associated parts off a difflock-fitted box to upgrade.
Post #781546 15th Jul 2019 10:37am
Mike c
Obviously this was quite inconsistent then, pot luck whether you got it or not!
Post #781548 15th Jul 2019 10:59am
MartinK
More info here
https://www.ashcroft-transmissions.co.uk/m...-lock.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #781551 15th Jul 2019 11:15am
