Home > Technical > Puma clock |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Take centre fascia off, remove the clock from the fascia and reseat/inspect where the buttons go for problems.
If you can be bothered to do that. Pull the clock fuse and then re insert when the time is right 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
13th Jul 2019 7:42am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 694 |
2008 Defender 110 XS SW - M57N2 / 6HP28X |
13th Jul 2019 8:43am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1750 |
Great idea. Thank you
13th Jul 2019 8:01pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Priceless Roy 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
13th Jul 2019 9:03pm |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 |
Try squirting some switch cleaner around the buttons - my radio used to mysteriously turn itself on often in the night when the vehicle was locked. Judicious used of contact cleaner solved the problem.
Alternatively, the previous suggestion sounds perfect!! Richard Defender 90 SVX |
13th Jul 2019 9:49pm |
