![]() | Home > Technical > Why is my oil filter different |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Have you tried an earlier or a later type oil filter? Might be that at some point you engine may have been replaced. Best way, check your service book, should have the engine number written in it, if its different from the V5 or engine block hey presto its had a new engine. Just a thought Ben
Rebuilt 1996 black/white Defender 90 300 TDi |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6712 ![]() ![]() ![]() |
Td5s all take the same filters.
It is a ![]() Have you measured the threaded holes in the new and old filters? ![]() ![]() |
mooro47 Member Since: 26 Apr 2011 Location: Surrey Posts: 29 ![]() ![]() ![]() |
Hi all the filter that is on the car is noticeably bigger with regards to the size of the threaded hole in the top. I've had to put the old filter back on and it went on easily enough. There was no way the new one(s) were going to go on It's definitely a Td5, I replaced the rotor filter no problem and the picctures in the workshop manual look like my engine.
Hmm OK - is there a reference number on the old filter at all?
Any progress with this?
FYI the Td5 full-flow filter has a 3/4" UNF 16 tpi thread. ![]() ![]() |
Martin
Haven't had a chance to take the old filter off yet but its on the list for Saturday. I'll make sure I measure up the threaded hole in the filter whilst its off and make a note of the number/make this time ![]() |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
Me thinks someone has changed something on this one.I have had experience of quite a number of TD5's both in disco and defender never come across this problem.But some times the flow filter can be a
![]() 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
