Home > In Car Electronics > CB gurus, I need your guidance
bear100
I have just purchased a cobra LX CB, next step is an aerial.....this is the bit I’m unsure of on a few points
Type? Are there different types for different cbs? Or particular brands I should look out for?
Has modern times taken over with a digital type?
Location? Not sure where to mount aerial many mount them on the front middle of the bumper but i don't want it there, how about to the right of the rear door on the gutter rail or roof rack? Or maybe opposite wing to radio aerial?
Length? Is there an optimum I would want a shirt one, I don’t like the long whip types.
Is cable length and route a factor? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #779410 28th Jun 2019 6:22pm
Mdm
not many cb places left that can offer real advice
cb shack at lymn truck stop or one at Wakefield jct 41 truck stop
Jim at communication eleven or cb11 is a good bloke been using him for 20+yrs
Post #779443 28th Jun 2019 8:47pm
donmacn
I've had a CB in the car for ages, but not a 'big user' - mainly for personal/occasional convoy stuff.
Just bought a new one though, and I found www.cbradio.co.uk to be very good. Think I might have bought the last one from them too.
I've used a PSM aerial mount before - on the rear of the roof on the nearside for me; and a stainless gutter mount above the driver's side B pillar.
At the moment the PSM mount is in use, but I've now got a roof tent which will foul that, so I was digging out the gutter mount to see if I still have all the bits.
Another handy thing in a LR, given the amount of ambient noise, is an external speaker which you can just mount to the roof lining above the driver's right ear. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #779446 28th Jun 2019 9:00pm
landy andy
You need to decide if you want it permanently or temporary.
Temp I would fit bracket to roof rack. That way easily removed and reapplied when required.
Permanent, I would go rear panel by rear door (where you often fit work light) or front wing, so it matches fm aerial.
You can get quick release mounts, so you don’t need a big whippy thing all the time. There is a good range of aerials on Thunderpoles website, and plenty of info. I think the do a CB aerial tha5 is short stubby black item, like the flexible FM aerials. The shorter the cable the better to a point, but you want at least a meter of cable to it. A gutter mount, for me, is a no no. They mark the paint, and often don’t stay on or snap, then causing other damage.
Post #779470 28th Jun 2019 11:14pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
I’ve also bought from thunderpole and can recommend. However an alternative source of equipment and advice is:-
http://4x4cb.com/
Post #779482 29th Jun 2019 7:18am
^^^That's Communication Eleven. Jim who runs it is a top man. Darren
Post #779584 29th Jun 2019 8:11pm
bear100
Thanks for the info Thumbs Up
Will give the mentioned suppliers a ring on Monday
I purchased the CB for an upcoming expedition and will probably only us it one such events so a removable type would be ideal.
Thanks chaps Thumbs Up 2023 Defender L663 V8
Post #779613 29th Jun 2019 10:21pm
