Home > Td5 > Is there a coolant drain plug on a Defender td5 block .... |
over the alternator in head not a lot good, depending on age td5 engine up to 04 lower rad pipe has drain plug
No block drain on td5 engine Last edited by dorsetsmith on 17th Jun 2019 4:42pm. Edited 4 times in total |
17th Jun 2019 4:27pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
Sound bit high up but o.k I'll have a look
Thx A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
17th Jun 2019 4:30pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
bottom radiator hose on some- remove it at your own risk though!
22nd Jul 2019 12:44am |
