Home > Maintenance & Modifications > BlusSea ST range terminal eyelets
As title suggests, the screws for the output on the BlueSea ST fuse box range I believe are the American #10-32 size if memory serves me correctly.
I'm pretty sure that this would take a metric 5mm I.D. Eyelet terminal on the outputs.
Could anyone confirm this please?
I'm not too keen on heatshrink terminals and would rather use tinned copper non insulated eyelets and my own adhesive heatshrink instead of various different colours.
Call me fussy, but all do the same job. Thumbs Up
Thanks in advance. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #777136 11th Jun 2019 9:31pm
leeds
The blue sea screws are 10-32 which is about 4.8mm.
Have just wired up a blue sea box and just used the small red insulated ring terminals.
If get half a chance I will check sizes tomorrow.
Brendan
Post #777143 11th Jun 2019 10:14pm
Thank-you Brendan.
Somewhere around 5 or 5.3mm I would have thought approximately. ____\We|Will|Win/___
Post #777146 11th Jun 2019 10:27pm
leeds
Slight correction.
Input studs for the positive and negative feeds in are 10-32 studs which are about 4.8mm
The screws for fastening the outgoing wires are 8-32 which is about 4.2mm
HTH
Brendan
Post #777219 12th Jun 2019 1:39pm
Thank you Brendan. πŸ‘πŸ» ____\We|Will|Win/___
Post #777231 12th Jun 2019 6:14pm
rallysteve
Yep, i used 5mm tube terminals on the power terminals and 5mm open barrel rings for the individual circuits and earths:
 02' 110 TD5 Double Cab Rebuild Thread
Post #777235 12th Jun 2019 7:13pm
Nice and neat. Thumbs Up ____\We|Will|Win/___
Post #777272 12th Jun 2019 9:16pm
