Home > Maintenance & Modifications > Rear door strut (V2 Vs V3)
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
I currently have the V1 rear door strut but I'm a bit tired of warning passengers to "open with care" or "keep hold of the door". It's had countless repair jobs.
Anyway, out of the two newer soft open, which is better? My head tells me that the newer model V3 will obviously be more thought out but I'm more of a fan of the mounting location of the V2.
What are you guys thinking?
Simon
Post #776257 5th Jun 2019 10:30am
K.M
United Kingdom 2016 Defender 110 Puma 2.2 XS CSW Montalcino Red
Out of interest, what brand are you looking at? This is on my list as a modification but given where I've started parking the Defender, I won't want a door that just fires open as it will go straight in to a wall!
https://www.4x4overlander.com/product/naka...p-mounted/
Post #776262 5th Jun 2019 11:36am
SimonDavies
The same as you have attached.
Stay away from the V1 in that case Laughing
Post #776271 5th Jun 2019 1:29pm
kmac
I have the v2 and it is unobtrusive and soft opening. Clearly if there are obstacles to prevent 90 degree opening, care is still needed.
Post #776280 5th Jun 2019 2:45pm
Co1
I have the v3 and it is discreet and controlled. A great little mod.
Post #776344 6th Jun 2019 6:17am
LCJ
I started with the V3 but found that it was flexing the top of the door frame where it was mounted too much, so changed to the V2 - much better IMO, and looks more factory and discreet too
Post #776356 6th Jun 2019 8:52am
K.M
Forgiving my ignorance, does the 'soft-stop' allow you to lock off the door part way through the movement so you don't HAVE to open it the full 90 degrees?
Post #776364 6th Jun 2019 9:54am
Stiff1
Deffinatly the V2 for me, just seems the best place to locate it, very OEM + strength of bottom section of door.
The soft action refers to when the door reaches its fully opened position, it will not stop with a jolt as in V1 which you really have to hold onto all the way. Instead it eases to the final position.
If however you only want to open the door part way, you have to hold it, there is quite a bit of pressure pushing it open depending on the incline you are on.
Also it does take more effort to close but still one of the best mods I have done.
Post #776431 6th Jun 2019 10:16pm
SimonDavies
I think it's going to be the V2 then. I did wonder if the closing aid on the V3 was worth going for but after reading another thread on here, maybe not.
Thanks all.
Post #776439 6th Jun 2019 11:20pm
leeds
Well over the years we have sold thousands of the gas struts. Version 1 is no longer available from 4x4overlander. Can confidently say that V2 is more popular then V3
V2 is slightly more involved in fitting as the door card has to come off and the reinforcing ribs need drilling. Take care NOT to drill the outer door skin. People comment that this one looks more factory fitted.
V3 or top mounted one is in theory easier and quicker to fit. Door bracket is straight forward. Main bracket goes behind grab handles but sometimes the grab handles have been fixed on different spacing Banging Head Banging Head so may need modification. Care is needed to attach strut to door bracket the correct way.
Both are relatively easy to fit if have a modicum of technical ability, the right tools and some common sense.
Brendan
Post #776442 6th Jun 2019 11:43pm
SimonDavies
Thanks for that. Do you have the V2 in stock Brendan?
Post #776503 7th Jun 2019 1:26pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
They Don't like it hot
loaded up the van for a long trip with the radio club in the sun
Went to shut the door and the strut has locked up - i can only presume from getting hot.
So I need a new one and some bigger screws now as trying to close the door pulled the plate off.
I presume I can order a replacement strut on its own?
Post #783042 25th Jul 2019 11:25am
Caterham
Shocked
all of a sudden I don't like the look of that mod so much.
Post #783058 25th Jul 2019 2:04pm
Thon
Could be an isolated case - mine spent several months in late 30's / early 40's temperatures out in full sunlight the whole time without fault.
Post #783063 25th Jul 2019 2:30pm
Rashers
Most if not all hatchback cars have gas struts on their doors. I've seen them fitted on access hatches on rooftops where the temperatures are baking. Never known one to lock. They usually fail in the other way by losing their gas.
Might just be a one off?
Post #783064 25th Jul 2019 2:34pm
