![]() | Home > Maintenance & Modifications > Sub Woofer connection |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i attached the earth wire to the front inner passenger seatbelt floor bolt - good connection, got a very strong reading on the voltmeter. BM52
Yep the blue "remote" must be connected also make sure the sub option is turn on and up on the head unit
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 335 ![]() ![]() |
Thanks Guys!
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
I have grounded here the power inverter (1000W) and had very bad results - it worked up to c.a. 150W and fried the fuse. Sub consumes less power, so it should be no problem I guess. Janusz www.yahodeville.com |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
If you have run the + to the battery...why not run the - there to!! Mike
I was wondering about doing that, but I was just following the instructions!!
Where possible its always better to run direct to the battery
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
For a quick fix, you can piggyback the remote cable directly onto the + terminal of the sub.
It will power up and remain powered up, so only temp for testing or it'll flatten the battery. Sorry if this is eggs being sucked, but the way it works is the amp will have a relay inside that switches on when power is recieved down the remote cable which essentially switches the main power onto the amp. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography Last edited by x-isle on 27th May 2011 2:04pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
As above i would try and go direct to the negative on the battery where possible. Only slight problem you may come across is afixing to the terminal itself. Good luck
