![]() | Home > Maintenance & Modifications > Rivnuts |
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 ![]() ![]() ![]() |
Hi
Would anyone know what size rivnuts I’d need for a lower front grill replacement ? Thanks Brendan |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
I drilled mine out when replacing the lower grill and used these:
http://defenderupgrades.co.uk/product/stai...con-grill/ |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
Seem great value ![]() |
Thanks, should have said pop rivets. Does anyone know what size I’d need if I went down the pop rivet route?
Thanks |
I'm pretty sure they're 5mm. When I swapped mine, I used M5 nylon nuts and bolts and I'm sure I didn't have to open out all of the holes. Darren
