![]() | Home > Tdi > performance boost TDI300 Defender |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
The variable nozzle turbo from Allisport or BAS (I think they’re the same part) is transformational. Install is relatively simple and the drive ability and power at all rpms is very different.
buckers19 Member Since: 02 Jan 2018 Location: London Posts: 95 ![]() ![]() |
Apologies for the sidetrack.
JimC, is the VNT turbo really that transformational? I’ve been toying with the idea but have been hesitant as I haven’t really found anyone that’s running it on a tdi. If it’s as good as claimed I’ll go in search of one. Instagram.com/mattbuckley19 |
A friend just recently installed one on his TDi, it’s so much better that it’s not even funny. Where normally you have to shift a lot to keep the turbo spinning and the engine in its power band, this just moves off like a petrol car. The turbo is always working for you and it will climb hills without downshifting and is much more drivable around town. It doesn’t add top-end power and speed really, but it improves daily driving substantially. Since the OP already has the improved intercooler and radiator, half the kit already is already bought.
Sounds like it could be an expensive week... Instagram.com/mattbuckley19
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
I have a VNT on my 200tdi which is equivalent to the 300tdi and I can vouch for the previous testimonials already mentioned. Definitely transformational but one thing to bear in mind is that a VNT will be weaker than a regular turbo, especially true if you increase EGT temps with the use of a Boost Pin. However the VNT remains the best upgrade IMO with a mild tune up on the pump along with the Boost Ring it quite honestly drives like a 'modern' diesel, without the lag and power everywhere where it wasn't before.
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1911 ![]() ![]() |
I want one
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 ![]() ![]() ![]() |
I was looking @ alisport site and noted the following: (VNT TDI 300) we advise against the use of a raised or nonstandard air intake "e.g. snorkel" and there is a reference to larger exhaust anyone has experience - as I don't want to lose the snorkel at this time |
there is also mention (forums) of a 3in exhaust option with VNT ?
rule of diminishing returns? |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250 ![]() ![]() ![]() |
Have you considered just playing with the fuel pump and giving it a good service?
After snapping two cranks I sourced another block and timing case complete. Previous owner had fiddled with the pump and what a difference! OK it just squeaked through its MOT but with a 2 tonne trailer and 1.2 transfer box it out pulls a mates Td5. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Was the " VNT Turbo " the cause of the 2 cranks snapping sako243 ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Don't have a VNT...
No a £30 crank pulley. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Thanks for the reply sako243
No worries. Boggo standard 300Tdi (albeit on it's third block and crank), original head back on it. Tweaked pump makes a hell of a difference though. Big hill eastbound on M4 by Bristol and accelerates comfortably pulling a trailer up it. Ed
Luckily i'm still on the original block / head, turbo and pump and yes the pumped tweaked a bit does help
