Home > For Sale & Wanted > [Wanted] Erberspacher D2 12v
excossack
I am after a Eberspaecher D2 12v diesel heater. Must be working and in good condition and must have at a minimum;
Digital control 801 or 7 day
fuel pump
exhaust
wiring loom
Basically complete enough to add 12v power source and a fuel source and get warm air.
What do you have? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #773114 14th May 2019 12:17pm
wyvern
You can buy a planar heater 'brand new' with all the bells and whistles from the main dealer with a 2 yr warranty for around £450 ... I have one in the 110 and its great !
The kit comes complete with everything and you can upgrade the timer and even add a remote to your phone
I had a D2 in the past and this is just as good but less money ! (no affiliation to the company - just a happy user)
http://planarheaters.co.uk/shop Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #773118 14th May 2019 12:57pm
excossack
Thanks Wyvern
I have now made a purchase of a almost new D2 airtronic heater
Time to hit the search function and see where people have mounted their heaters. 1999 Defender TD5 110
Regards
John M0VAZ
Post #773237 15th May 2019 1:32pm
JWL
Under the second row seats, passenger side. 90degree elbow on the outlet blowing in the direction of the cubby box, very easy to put the holes through the seatbox for the burner inlet/exhaust. Close to the fuel tank if you wish to draw from there whereas I use a small tank under the bonnet using red diesel.
On the exhaust/inlet for the burner I put the exhaust just in front of the passenger back wheel and the inlet draws fom where the pipe is tucked up under the seatbox above the rear prop.
I've had it running when doing the likes of Strata Florida and never had any problems
Post #773250 15th May 2019 2:55pm
wyvern
I had a D2 fitted in my previous 110 under the 2nd row seats and it worked very well there - but not if you wanted to carry lots of loose things as they can block the intake/ outlet ...
in the current 110 we have our Plantar heater mounted under the cubby in a special mount that works very well - (same size as D2 )
available from Nakatanenga @ €99 or from Brendan & Barbera at 4x4 overland on here (leeds)
http://www.nakatanenga.de/zubehoer/innenau...skonsole-2 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #773252 15th May 2019 3:11pm
excossack
Cheers. I don't have room under the cubby box on my 110. Under the rear seats will be my chosen location. Warm air ducted to the rear and then into the footwells (middle seats) and hopefully front seat foot wells.
I like the idea of a separate fuel tank under the bonnet.
JWL - do you have pics of your install? 1999 Defender TD5 110
Regards
John M0VAZ
Post #773530 17th May 2019 10:51am
JWL
I'll try to get some tomorrow. All I used was a secondhand Ford Orion coolant header tank, first one I came across, zip tied in the space between the heater box and the front suspension strut. The pulse pump is under there with the fuel pipe running down and along the chassis rail to the heater. No issues with the heat and the tank under the bonnet, can be a little awkward filling but I either use a can with a spout or a funnel and a full tank around 1½l will last 18 hours at constant use, generally in wintertime it's on for two to three hours a day and I'll check and fill about every four days.
The controller, on/off switch I've fixed on the fuse cover in front of the gearsticks.
Post #773656 17th May 2019 11:13pm
