Home > Puma (Tdci) > Clutch - Can't engage gears with engine running
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
I've tried sifting through the various clutch threads but can't find a relevant thread for the symptoms.
This morning all was good, the 07 2.4 TDCI drove like normal.
This afternoon on the way home from work I managed 5-10 normal gear changes, then the gear changes rapidly declined in quality! They started to make that crunching noise when you force it from one gear to another but not continuous like if you try to change gears without using the clutch at all!
Here are the symptoms:
The clutch pedal operates and feels normal.
There is no issue with disengaging gears. (no surprises there!)
While in gear, driving is normal (other than not changing gears!!!)
With the clutch depressed, I can't engage a new gear without forcing the gear stick (significant effort) while lifting the clutch (a bit like when the syncro doesn't line up for reverse).
When I do the above to change gear, it changes with a crunch but not a long grinding noise like when you are not using a clutch and don't match the engine revs and speed.
Transfer box changes all operate like normal with engine running.
Gear changes are fine with the engine off.
If i start in gear with the clutch depressed then the engine labours to turn over (the battery is on its way out anyway but still has enough juice to start fine enough).
The clutch fluid level had dropped about a centimetre (half an inch in old money) but not enough to draw air into the system, also topping up didn't help.
The vehicle is only 1 yr old to me, I'm not sure of the clutch history but haven't noticed anything untoward in the time I have owned it. There has previously been a slight rattle with clutch out that goes when the clutch is depressed but nothing that I would describe as a 'death rattle' - it is drowned out by the fan on only the middle setting! Having previously thought that this minimal noise was normal, i'm starting to wonder if I have made a grave error Shocked .
I'm hoping that there is a relatively straightforward answer and that I just didn't find it. For now i'm hoping that someone far more knowledgeable than me weighs in with their thoughts and experience! Bow down
Post #773026 13th May 2019 9:34pm
MK
Sounds like a knackered friction plate. Puma 110" SW
Post #773033 13th May 2019 9:42pm
Roger
Thumbs Up Either way, I take it I'll need to drop the clutch - was definitely hoping for a simpler fix! Rolling with laughter
Post #773043 13th May 2019 9:59pm
LR90XS2011
could be the springs have given up the ghost and left the hub causing drag (ie clutch plate caput) DEFENDER 90 TDCI XS,
Post #773065 14th May 2019 6:24am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Just check the clutch fluid level. It might be worth giving it a quick bleed through to see if it improves.
Post #773082 14th May 2019 8:08am
Roger
Thanks for the replies. Thumbs Up
William, the pedal still feels firm, topped up the fluid (only took 1 cm) so I am confident that is not the issue - I was hopeful though!
LR90, regrettably I think that is indeed the problem area, I chatted to a former vehicle mechanic at work and he is confident that the release bearing has died. Either way i'll have to skin my knuckles and drop the clutch! - Pictures will probably follow depending on how frustrated I get! Laughing
While it is out, i'll replace the clutch (up-rated from clutchfix - anyone recommend a particular supplier? otherwise i'll go cheapest) cover and release bearing (+ slave kit). I'll also check the spigot bearing and output shaft. Is there anything else I should be checking or any pitfalls to watch out for? Otherwise i'll just mine the forum for the relevant topics when I get stuck! Big Cry
Post #773129 14th May 2019 4:39pm
Sulisuli
4x4 overlander run by forum member Leeds also know as Brendan sells them Thumbs Up great to deal with, brilliant customer service, but don’t ask for a discount, if you do just remember I warned you not too Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #773140 14th May 2019 6:28pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Speak to Luke at LOF clutches. He specialises in Land Rover clutches. Tell him Jeremy sent you his way. Just ordered a clutch from him yesterday. Recommend you upgrade to 2.2 release bearing and also replace the output shaft. They do everything you need in a kit.
Post #773149 14th May 2019 7:04pm
LR90XS2011
might be worth replacing the transferbox adaptor shaft whilst the g/box is out, lots of people recommend to Ashcroft Kit, Ive got one but not fitted it yet DEFENDER 90 TDCI XS,
Post #773167 14th May 2019 8:34pm
jst
Change slave Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #773197 14th May 2019 10:18pm
Roger
Turned out I underestimated the amount of rattle that constitutes a death rattle, problems were caused by an escaped spring....
Had a good weekend pushing my mechanical ability.... and my luck with a homemade hoist that would make Heath Robinson happy!
The spreader plank was to safeguard the door sills; i know the roof rack will take the weight but wasn't sure about squeezing at the sills.
Post #773922 19th May 2019 9:56pm
boxoftricks
Brillant bit of initiative shown Rolling with laughter
Post #773923 19th May 2019 10:01pm
Procta
me and my dad had fun and games, but then again he did it all arsehole over backwards, Instead of thinking things out 1st. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #773937 20th May 2019 6:14am
