Home > Puma (Tdci) > Puma stereo in another car
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have sold my original stereo to a friend with Jeep.
Everything works fine, but the security code - he needs to type it in every time he starts the engine.
Is there a non-ISO signal fed via ISO connector by Puma to prevent it? Or something is definitely missing from the connector on the Jeep side?
Cheers! Janusz
www.yahodeville.com
Post #72645 25th May 2011 7:48am
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
When he enters the securit code, does the device load the preset channels from before?
Jack
Post #72646 25th May 2011 7:50am
dgardel
Italy
Re: Puma stereo in another car
Cheers!
Look for the main power.
there are two +12V cables, one on battery (so the radio do not ask the coda all time) and the 2nd one +12V switched.
The LR radio have ISO connector (socket A and B on the attached pic.)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #72649 25th May 2011 8:02am
yaho
Thanks, will take a look (should look for these diagrams first Embarassed )
Cheers! Janusz
www.yahodeville.com
Post #72653 25th May 2011 8:32am
JSG
It's probably just the LR stereo rejecting the Jeep Thumbs Up John
2011 Tdci 110 CSW XS
Post #72666 25th May 2011 10:24am
yaho
http://en.wikipedia.org/wiki/Transplant_rejection
Quote:
Transplant rejection occurs when a transplanted organ or tissue is not accepted by the body of the transplant recipient. This is explained by the concept that the immune system of the recipient attacks the transplanted organ or tissue. This is expected to happen, because the immune system's purpose is to distinguish foreign material within the body and attempt to destroy it...
It may be destroyed! Laughing Janusz
www.yahodeville.com
Post #72668 25th May 2011 10:34am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Cheers!
I had exactly the same behavior. As Dgardel sys, is about the two +12V cables. Make sure that they are not swapped (pin 4 on pin 7). In this case the radio will work fine but will lose memory when the power is cut.
Post #72690 25th May 2011 1:37pm
yaho
Swapping 4 with 7 fixed the problem and earned me a beer Very Happy
I can share it with you guys, if you are around north-east Poland. Thumbs Up Janusz
www.yahodeville.com
Post #73012 27th May 2011 7:49am
