Home > Maintenance & Modifications > DIFF GUARD PROBLEMS
kenhills
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
DIFF GUARD PROBLEMS
Just tried to fit diff guards from Flatdog and they are a real dogs breakfast. The fastening supplied don’t fit and are the wrong thread. Even the fastening for the Flatdog to Flatdog bracket appears to be the wrong thread. Sad Sad
Does anyone know what the correct thread is for bolts on the diff. UNF? Ken
Post #771676 5th May 2019 9:47pm
Believe it or not, right to the end the axles and diffs on a Defender use a mix of metric, Unified, and British Standard threads. Which fasteners on the axle/diff carrier are you using?
Post #771683 5th May 2019 10:43pm
benniferj
What car, what type of axle?
I put a wild bear rear wrap around guard on a 110 52 td5 with the later non salisbury rear axle. The bolts that go into the diff housing sideways that came with it were too long and bottomed on threads. So I bought some new bolts that were shorter and all good.
If its all wrong and you can't source any new bolts then speak to who sold it to you and get them to sort out a proper kit?
Post #771702 6th May 2019 10:05am
kenhills
Its a 2008 110 Puma. I am happy to source the replacements myself rather than faff around chasing an incompetent supplier. Ken
Post #771704 6th May 2019 10:46am
Mcmuffin
Belgium 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I 've had the same problems with flatdog guards. And when you finally find the right bolts, the guard is not fitting at all. At my guard it looks like the welded part with the two holes is welded on the wrong side of the marked line.....
Post #773894 19th May 2019 5:53pm
