Home > Puma (Tdci) > Injector seals - precautionary change?
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Views please...
My 2015 2.2 has just passed 11,000 miles now, with the road speeds here mostly being a 40mph limit (ahem) it doesn't get worked too hard. It has a BAS 150 remap as well.
The injector seals are clearly a significant weakness from the number of posts about them, but what's the collective view on whether it's worth changing them as a planned service item at some point before they fail, and if so, at what sort of mileage/age? I see stories of failures that seem to be at fairly significant mileage but also some that happen a few times a year, so it's hard to get a feeling for what the normal life of them is.
Any thoughts, or is it really just a 'keep an eye on it' thing? Tempted to lose some of the plastic tat on top of the engine to make this easier if the answer is the latter... ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #771486 4th May 2019 11:54am
Caterham
mine are original at 100k miles and no issues so far.
also have re-map so I'd say leave be.
I think for the most part they don't fail and leave you stranded. tends to be a progressive problem.
on the other hand disturbing could create a problem if the works undertaken by a buffoon at you local LR dealership Mr. Green
Post #771505 4th May 2019 1:55pm
lohr500
For me, I think the old saying "if it ain't broke, don't fix it" would apply on this one.
Post #771526 4th May 2019 5:18pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I would (have) put it on my check list when doing a service. It’s Just 2 bolts, costs about 3 min to check. Wouldn’t replace them if not broken. You know most problems occur after repairs Or service Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771534 4th May 2019 6:25pm
BogMonster
Sounds like a plan. Thanks Thumbs Up ---
Post #771629 5th May 2019 4:29pm
Mine are original at 240,000 miles.
If you're going to replace serviceable items on a "just in case" basis, where will you draw the line?
Post #771630 5th May 2019 4:35pm
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Re; The "if it ain`t broke don`t fix it" theory - I stripped the top end of my V8 recently as No.2 cylinder inlet valve was leaking slightly (whistling back though the inlet manifold when cranking, if you`re interested!) so lapped in the valves on that head and it was sorted. Looked at the engine and thought "Well as its dismantled so far I might as well do the other head"
As I am slackening off the head bolts in sequence "Tink!!" - one snapped with hardly any effort applied.
Sinking feeling! These are the "stretch" bolts and I guess that one had been overtightened on assembly but was just holding together - until I applied reverse torque.
SO, "If it ain`t broke" think hard and long before disturbing things.
And to justify this in the Puma section I suffered an injector "hosing" on my 2.2. Land Rover would only change the one injector under warranty, despite evidence that all 4 were not operating correctly - eventually gave up and went to a local Diesel injection specialist who changed the other 3 and "calibrated" them, if that is the correct term, - it was like a different engine. And that was 20,000 miles ago. I can recommend Diesel Bob. Don`t drive faster than your angel can fly!
Post #773552 17th May 2019 12:43pm
