Home > Maintenance & Modifications > How much Silent Coat do I need for the rear of my 90?
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
I'm going to start sound deadening the rear of my 90 hard top. I want to use Silent Coat 2mm Mat and I was just wondering if anybody can tell me whether I need to buy the "bulk" package which has 40 sheets or is the 20 sheet one enough? I'm going to do the bottom and the arch boxes too to start with
Post #771167 2nd May 2019 9:04am
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I need to know this too, although I'll end up using a mixture of both 2 and 4mm
Post #771194 2nd May 2019 11:14am
PCM
I just rang the very helpful guys at https://www.deadening.co.uk/
They made a package suited to my 110 CSW with silentcoat 3mm all over and top foam for the roof lining too.. and after I'd done it all I had very little left so for me their numbers were spot on.
They sell everything you need and also gave me a discount for buying all the bits in one go.
01865 343934
Can't recommend them enough.
PCM
Post #771207 2nd May 2019 1:21pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Thanks for the link PCM.
Post #771211 2nd May 2019 1:49pm
PCM
Thumbs Up
Post #771223 2nd May 2019 3:00pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
10 will be more than enough for the floor and wheel arches. Silent coat isn’t the best for the roof as it has been known to lose it stickiness under heat ( hot days ).
Silent coat/dynamat or any butyl covering is designed to reduce vibration and isn't a sound barrier. If you want to reduce road noise in the rear, consider a 3mm acoustic rubber mat stuck down with a suitable glue and possibly a carpet if it’s feasible.
When fitting the butyl mat, use 100mm strips in the rear to provide mass to the flimsy aluminium panels of the rear area.
Covering the entire area is a waste of money. Companies will tell you otherwise as they love people who want to spend money and have seen the build projects where the interior of a defender is plastered with it.
Post #771238 2nd May 2019 4:34pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
As an alternative, i used this stuff
https://www.ikoustic.co.uk/products/wall/t...gLU8fD_BwE
one roll is easily enough for a 90, and it does both airbourne noise and dampens vibration, very easy to work with and thin for under carpets, ive only done the front footwells and seat box so far but the difference is amazing. Its recommended as a building product but also used in aircraft and automotive.
Post #771245 2nd May 2019 5:07pm
sgreenham
Thank you very much for the tips. I've ordered some Silent Coat from the sound deadening shop with forum discount so we will see how we get on.
Post #771257 2nd May 2019 7:08pm
PCM
You'll soon become obsessed with chasing the decibels.
It's a slippery slope, but one that means i can now hear the kids arguing in the back. Very Happy
Post #771639 5th May 2019 6:12pm
